mini_mull
I had the hubby take the burb in to get the alignment checked on the burb today. I installed a 4" TCI front spring w/DIY4X rear shackle flip and new 285/75R16 pro comp mud terrains a couple weeks ago, and wanted to make sure everything was lining up good so I wouldn't wear my new tires funny. The front desk girl called us and told my hubby the camber was off and they needed to install a set of "cam bolts" to correct it. I didn't think camber was adjustable on our SFAs, so I got on the phone and asked her how, and she said they attach to the control arms. I said I don't have control arms, so she said hold on and came back and said they install on the ball joint. They wanted $150 for both sides and $70 for the alignment.
Here's the alignment report:
Camber
LF 0.4 degrees RF 0.4 degrees
Caster
LF 9.1 degrees RF 8.9 degrees
Toe
LF -0.23in RF +0.31in
When I got it done last December at a different shop these were the readings after adjusted:
Camber
LF 0.9 degrees RF 0.4 degrees
Caster
LF 9.8 degrees RF 9.6 degrees
Toe
LF 0.15 degrees RF 0.00 degrees
I expected them to just fix the toe like the last shop so their "cam bolt ajdustment" caught me off guard. So I did some searching here and figured she must be talking about the adjusting nut for the upper ball joint. I also saw some adjusting shims that can be installed between the spindle and the knuckle. I've found different opinions in old posts about whether these methods worked and/or were safe, since none were recommended from the factory.
My questions are, if you do think the methods to adjust camber are safe do my measurements warrant a camber adjustment? Or if you don't think they are safe, can you tell me why? Finally, if I decide not to get the camber adjusted should I take it back in to adjust the toe, or just attempt to adjust it in my driveway?
Thanks for the input, you guys are a great source of info and advice and I appreciate all of it.
Camber
Caster
Toe
Camber
Caster
Toe
