alignment question
Lagerdrinker
Registered Member
Delco PA
On my 91 what alignment changes can be made? Obviously toe is adjustable but is camber adjustable? My r/f wheel looks like it has positive camber and it rides ok but little loose.
Its likely a ball joint or wheel bearings in need of replacement.
Camber is technically adjustable but it almost never needs to be messed with.
Im not ruling anything out but wheel bearings are quiet and over bumps i dont hear any knocking usually associated with ball joints
Jack up that side of the truck and see if there is any in/out movement at the wheel.
Worn out balljoints or wheel bearings don't always make noise.
Thanks guys, i wasnt sure if live axle was adjustable. I havent looked at it yet but atleast now i know what to look for(wheel bearings and balljoints) and that adjustments can be made if needed.
