All gone
I'm still looking for simple tests for the gauges. I'll let you know what I come up with. I found one for the temp gauge but you'd need a 75ohm and 1400ohm resistor to do it. Can't find anything for the oil pressure gauge. The volt gauge should be as simple as applying voltage across the contacts. You could just put jumpers across a hot 12V battery and see what it reads. Should read about the same as a multi-meter.
I'm sure that the oil pressure is resistance based as well, but I have not found the ranges. I'll keep you posted man!
with shipping charges
$30 for the 85 gauges and printed circuit
$70 for the new Dove Gray carpet
$45 for the new raised arm
$15 for the new speedo cable (basically paying for shipping)
$60 for the 70s gauges w/ tach
$300 for the bike and crap load of new parts
$15 for a new hayden HD fan clutch
$10 for new swaybar mount bushings
Free for any of the misc pieces
ttt
carpet is sold
I just found a Brand New 2wd pitman arm for mid 80s 2wd. I think it's Moog. May fit other years, dunno.
can you give me a center to center bolt pattern measurement for the clutch fan?
I'm out of state atm. Will be back Saturday.
PS: Why does NM have so much road work going on! Damn 40 gezz
Is the 70s era Tach dash still available? Can you verity that the tach itself works (I'm not worried about the other gauges). You can just hook it up by itself to your HEI and tell pretty quick.
If you have another way to check it I will. Currently I have no engine in the truck. If I can hook it to my quad I will lol.
sorry, bushings are gone, I wasn't sure if I gave them to my cousin or not. They worked on his 3/4.
