While installing my NWF cable shifters on my doubler yesterday, I came across 2 problems.
1) the pass. shift rail on the 205 is too short and does not allow the cable to reach it
2) the bracket that connect into the driver side shift rail runs across and under pass shift rail and prevents anything from bolting to it.
it seems that I have the only 205 with this problem (equal length shift rails) since EVERY pic I look at has a longer pass side then driver side.
My questions are this.
1] when my205 was rebuilt, could they have put 2 driver side length shift rails in by accident?
2] could the 205 be opened up and adjustments be done to allow the pass side to extend further out?
3] should I just go buy a longer shift rail or just fab an extension piece some how to the existing rail?
4] when it comes to the ball bearing and spring above the shift rail. I see 2 notches not 3. Is that correct? I thought from the pics I look at that there is 3 notches "positions" the ball bearing can sit in?
the pics below are of my 205 and the last pic is of a stock 205 I pulled from the internet. As you can see its shift rail is like 1" - 1 1/2" longer than what is in my case.
My case came out of a 72 Blazer
thanks in advance
thanks in advance
