All of a sudden a huge cloud of smoke....
scoutillac
Spokane, Wa.
I put a PS cooler on today hoping to help things run cooler. So here I am driving to Jiffy lube right before work to do the 500 mile breakin change. I did the math it was cheaper to have someone else change the oil. About 2 miles before I got there this huge cloud of smoke starts blowing out from my burb. It was big enough the car behind me about stopped. I figured I was on fire. Luckily I wasn't. One of the lines on the low pressure side blew off. My entire engine compartment and the whole underneath of the burb is covered in PS fluid. Holy hell that was scary. All I could think was there goes my new engine. The only reason for it I can think of is the higher flow from drilling out the pressure side bushing thingy created more pressure on the low flow side than the hose could handle. I guess I need to flare the hose a bit more. All is well. Any of you have a scary moment like that. I mean a time when you thought everything just went to hell in a handbasket, but it was really nothing big? Tell about it.
I've seen rigs that did what you describe burst into flames seconds later so I'd say you were lucky.
Yeah, I had an incident with ATF on the exhaust manifold (due to an idiot PO /forums/images/graemlins/angryfire.gif ), so I think you lucked out. I imagine if, exposed to the right heat, any petroleum product (ie PS fluid) will burn.
Mine had 6" flames under the hood /forums/images/graemlins/eek.gif
-- A
[ QUOTE ]
[/ QUOTE ]
How did you make the connections between the hose and the cooler?
[ QUOTE ]
[/ QUOTE ]
My buddy's rig which was on the cover of Peterson's had about 6' tall flames coming from it when he shut it off and ran for the fire extinguisher
What kind of truck is your friends? What month of petersons was it in? Why was there such big flames /forums/images/graemlins/yikes.gif /forums/images/graemlins/eek.gif
[ QUOTE ]
[/ QUOTE ]
I was going to use the factory crimped hose end, but the aluminum tubing had a pin hole. So I cut the hose and hose clamped it to a tube with fitting that came with the burb. The crimped part of the tubing wasn't real big. It almost looked like it was rubbed down. So when I get back home I'll add a little more crimp and double clamp it.
Typically the high pressure side is the one that uses crimped connections. /forums/images/graemlins/eek.gif The low pressure side just uses hose clamps. Pressures on the high side can reach 1200+ PSI. /forums/images/graemlins/yikes.gif That will blow your cooler apart. Make sure that you have the cooler plumed into the low pressure side of the system. /forums/images/graemlins/thumb.gif
my wheel fell off twice from bieng walloed out. it was kind of scary once i was on the entrance ramp of the freeway, the other i was in the dirt off roading.
[ QUOTE ]
[/ QUOTE ]
Er, I think you replied to the wrong topic. /forums/images/graemlins/eek.gif /forums/images/graemlins/blush.gif
[ QUOTE ]
[/ QUOTE ]
I think he replied to this from scoutillac in the first post of this thread /forums/images/graemlins/thumb.gif
I thought it was a reply for the thread where the guy keep losing his aluminum wheels because he was using the wrong lug nuts. /forums/images/graemlins/eek.gif
[ QUOTE ]
[/ QUOTE ]
I might be dumb, but I'm not stupid. Or however you want to politicise the word.
[ QUOTE ]
Pressures on the high side can reach 1200+ PSI. That will blow your cooler apart. Make sure that you have the cooler plumed into the low pressure side of the system.
[/ QUOTE ]
I did double check everything before I even started to add fluid. I flared the tube a little bit and added another clamp. No prob since.
