All of what I've learned today...
broncoman6524
chuluota Fl
So today was my day off. Which meant I had High hopes of getting my motor broke in....:D:D
To begin, I installed the p/s pump into brackets. Then comes the pulley...For anyone whos tried to intall P/s pump pulleys know how much this sucks. Started at 11am, got the pulley installed at 8Pm...:eek1:
Granted this whole time I had gave up and fought the motor to crank over and start.
Apparenly if you don't have a ground direct from batt to motor then frame. It won't turn over...:doah: I was using a ground from battery to frame...and forgot the rest.
When I turned the motor over, the Temp sensor wire winding would start to smoke.:eek1: Guess the block was trying to find a good ground. :eek1: So I ran a ground from batt to motor, and batt to frame, the block to cab.
Motor cranks, no compression....:confused: Come to find out I adjusted the rocker nuts one turn too much. Which was holding the valves open and there-fore NO compression. So I back the nuts off one turn, motor starts to TRY and start. With no avail.
So, If I pump the carb and hold it open it will fire. Rev up, then slowly die. As if it's running out of fuel.:mad:
Sorry for Long ass post...i guess tomorrow I'll start with checking the valve adjustments, then play with the carb.
But the cheap tool from Harbor Freight :wink1:
Take about 2 minutes to install or remove the pulley.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40749
[FONT=arial, sans-serif]Pulley Remover and Installer Set[/FONT]
[FONT=arial, sans-serif]Remove and install pressed-on alternator and power steering pump pulleys. [/FONT]
  • Comes complete with adapters for the GM 3.1L and Quad 4 motor's unique style pulleys, as well as Ford's 4.6L metric requirements
  • Has reversible split jaws for easy access to pulley flange
  • Works with most domestic cars and light-duty trucks, and some heavy duty trucks with belt driven pulleys
  • [/FONT][FONT=arial, sans-serif]ITEM 40749-2VGA [/FONT][FONT=arial, sans-serif]$14.99 [/FONT]
