Allison 1000 trans fluid
SpeedlabDan
Keepin it trashy never classy
Woodstown, New Jersey
OK ladies and gentlemen, quick search turned up null so what are yall using for fluid and what's the best, most readily available etc? Tanks a lot!
my master fluid spec book made by motor info systems gives
dex vi = dex-6 fluid.
capacity showing 7.4 qt . if i was a betting man thats a pan service refill spec .
info for a 01-09 2500 - 3500 vehicle .
when you service the spin on filter make sure to clean and swap over the magnet . it sticks to the filter and guys dont notice it and discard it .
I knew I should just messaged you haha OK so 8qt + of dex6. Thanks man
Dex 6 is what gm puts in it but allison spec is tes295
And dex 6 aint it...
I would not cheap out on my allison. We run them at work and they put Mobil Devac in them. In a fleet that cuts every corner possible.
