Almost Complete K5 Tube Truggy
badboycrawler
Registered Member
Sherwood, OR
This is it, 1st time out was Blazer Bash '07', Everything was new and fresh 1 year ago, started as a K5, only approx 6' of frame used the rest is all tube chassis, 4 seater, 454ci Vortec w/custom air intake , reworked computer, Howell wiring harness, Gibson SS exhaust, Flowmaster mufflers, runs great and strong, Turbo 400 all custom HD internals, including Art Carr converters and manual/reverse shift pattern valve body, Atlas II T/C, 4.3 ratio, 1410 outputs, 1/4" wall drivelines by Driveline Tech, Dana 60 High Pinion w/Dedenbear C's and Knuckles, WFO steering arms, Yukon 4130 shafts and super joints, Poly Performance drive flanges, 14 bolt FF w/Yukon 4130 shafts, disc brakes, both axles have cut and shaved bottoms for clerance, w/HD covers, 5.13s, Detriot lockers. PSC full hydralic steering w/2 1/2" double ended ram, 4 linked and set up for coilovers, 4 link links built w/1/4" wall tubing and uses 1 1/4" x 1" hiem joints, Beard Super G seats w/5 point harnesses, and seat covers, Warn winches front and rear, front has nylon winch rope, Ron Davis radiator (rear mounted), Autometer gauges, fuel cell, also some extra parts are included, full belly pan under motor and trans and T/C, New vinyl graphics added in May '08, "ALL IT NEEDS IS COILOVERS, RIMS AND TIRES, EVERYTHING ELSE IS HERE AND WORKS GREAT". Asking $20,000.00, So for approx. $25,000.00 invested you will have a $35,000.00 RIG, Buyer responsible for shipping, However depending on location may be able to help with the shipping, PM me w/email for more pics and info
