alot of stuff... chevy parts.....
RootBreaker
3/4 ton status
Williamstown, NJ USA
miscellaneous stuff for sale....
this stuff is going to go on ebay REALLY SOON... NEED CASH
sorry digital camera broke - need a new one.. hence stuff for sale...
however will borrow one for pics
you can make a reasonable offer if you choose...
I will list what vehicle the parts are from (so vehicle is not for sale as it is not here)
1985 GMC Jimmy parts
~~ Front Driveshaft - Junkyards want $75 - Ill take $50
~~ NP208 - smc465 to np208 adapter sold
~~ Center Console with lock and key - $40 - sold
~~ Gauge Cluster - $25 - sold (saturday)
~~ Gauge cluster covers top and bottom - $20 vented from AC unit -sold (saturday)
1976 3/4ton chevy pickup
~~smc465 mated to a NP 205 with cross member and front drive shaft - $250
1991 caprice police car (9C1)
~~ Oil cooler, hoses and adapter to bolt to block.
all that is needed is couplers to connect hoses to cooler
One hose has a outter crack but doesnt leak so seems good
$75 - guy I got it from sells it for $135 for what I have
1978 chevy 3/4 ton pickup
~~ Clutch pedal/brake pedal assembly - $75
~~ Clutch rod - may need ends welded to booger it as it shows wear parts then grind - $10
~~ Clutch rod extended when I had a 3" body lift - $20
~~ Bellhousing for mechanical clutch - SMC465 to motor (could do others as there are other bolt holes) - average junkyard price is $75 - Ill take $35
~~ Front driveshaft to NP205 - when my truck had a 12" lift so it is extended and I will measure - Paid $200 take $125 still new
~~ 2 fairly new drums (never turned) and brake hardware and shoes..... FREE
I have more and will list later.. and some pics.... will dig up what I can....
Gauge cluster and you can see part of the cover - sold
Center Console with lock and key - sold
Sorry pic shows it dirty... will clean it... seems digicameras show dirt like you wouldnt believe!!!!!
Just pics on the few items... will get pics of all... hopefully by tonight....
Jeff
p.s. you can guestimate shipping via fed ex ground from 08094 to you... guess weight and dimensions to get a rough $#
ftwk5 said:
how much for the center console shipped to 76036? thanks.
fedex ground is $15.27.... make it $15 even....
also has a piece of carpet insert that someone cut out... also has the 4 bolts to bolt it down..... nice condition...
will borrow my neighbors digi cam tonight...
sweetk30 said:
dibs on the 12" lift shaft. what joints on the ends thanks.
will snap a pic tonight...
will also compress and extend and give the measurements....
joints.... hmmm pinion end.. NONE.... cv end.... normal ones... cv has been ground down to allow clearance when it was under my truck with 13" front leafs and a d44......
$25 for shipping.... (heavy so if more... dont worry about it... :wink1: )
compressed I think it was 28 1/2 and extended was 31 3/4
ftwk5 said:
console on its way to ya.... sorry i didnt clean it... dirty biatch too :haha:
however did a hookup fer ya... :wink1:
I verified the key works.... and also threw in the door locks that the key matches..... not a big throw in but hey a lil something :laugh:
