I noticed something when I start my '85 Burb (6.2) up --when the fast idle is working after a cold start,the dam altenator belt squeals like a stuck pig for the duration of time the fast idle is "on"--soon as it shuts off and lets the engine go back to normal idle speed,the squealing stops--and wont return even if I rev it up ,so I asume the belt isnt slipping,U've adjusted it and tried a few different types of belts,a few seemed to not squeal as bad but they did not fit well in the pulleys and one got launched...so I'm back to the correct Gates # belt,the one that squeals the loudest..
I'm wondering if the fast idle solenoid is drawing too much juice??--seems like it drags the altenator down a lot until the engine warms up and it shuts off the fast idle...I haven't looked to see of its fused or not,I'd asume it is,and would pop the fuse if its drawing excessive amps??..
Anyone else notice their alt. belt squeals after a cold start ??...My '82 pickup with a 6.2 doesn't do this,but I'm pretty sure the fast idle isn't working on it too,it never has a fast idle ,nor do I hear a drop in idle speed after it warms up...
