alternater bracket
Check with your local auto parts store, I know the one here can get them (aluminum bracket for P/S, ALT) and IIRC it was only about $45.00 and is an AC Delco part.
i have a bucket full of those brackets. do u need passenger or drives side, one? second r u running a long or a short snout water pump? do u need the spacer for the lower alt. bolt? ive got them all just let me know what u have. $15.00 shipped sound fair?
His is serp set-up which means it is one LARGE aluminum bracket for the drivers side that holds both the P/S and the Alternator.
Good Deal Ill send you a pic of the bracket after I get the pulley off. Im still not sure what all the bracket is holding Thanks
brackets
Indy here are two pics I need to replace both brackets . Can you hook me up?
Thanks let me know Brett.
[/ATTACH]
