I have a 89 k5 350 had alt tested it's good. But I've tried running a switched 12 source to it still notta it dosent show power at the stud. And when the grounds pulled it stalls.
Plug should have some letters on it that coorospond with the wiring locations. You need to supply 12v switched power to the correct terminal, out power to each of those terminals and see what it does. One of them will keep the alt excited even withbthevignition off and run the battery down another one will excite it and charge as normal. Not sure what the other two do.Cs130
