bnate
OK, I'll add my .02 to the thread. I believe you are referring to my thread when I was trying to do this a few months ago.
What I came up with is having a buddy of mine weld on a steel dowling onto the END of the hinge pin and then drilling THAT piece....which is not hardened steel and a PIA to drill. Thanks to 78Suburban for sharing how to actually drill these. I might try this if needed.
Another way to score the pins would be to put a disc cutting wheel on a bench grinder and then hold the pin.... turn pin at 90 degrees....
Good luck.
Good luck.
