Is there any advantage to upgrade the stock size wire from the alternator to the battery? I just replaced the engine side harness on my truck which has the stock size charging wire and fusible link at the batt connection. I wondered if this size is up to the job. I have a 105 amp alternator that I put on when I put the TBI motor in and will be mounting some auxillary lighting and a winch soon. I don't want to roast my truck in flames by putting a larger wire on there, or not get the charging potential I should so let me know your opinions. Thanks!
