dixiechevy01
I have an 87 k5 blazer with a 350tbi, I was driving home in the snow the other night had it in 4 hi, headlights on, wipers on, and the defrost on high and it seemed like the alternator surged and the belts squealed and the voltmeter went down around 12 or 11 volts. So I turned the defrost off and it was ok after that. It did this a few times after that also but it seems like its only if I have it on defrost with everything running.
I was thinking loose belts or the alternator might be bad. It was replaced about 3 years ago and I don't put that many miles on this. The belts were ok the a/c belt could be a little tighter but I didn't think that would affect the alternator because its on another belt. I was also thinking the gauge of wire from the alternator to the battery might not be thick enough. What gauge should be run for that wire and if anyone has any other ideas let me know.
..usually only does it a short time,on lower speeds,then it gradually goes away...I drill a tiny hole in the motor's bearing "bump" on the firewall side and put a few drops of light oil in it,that cures it for another few weeks usually..
