mtnman210
When I went to start the truck this morning it started as if the battery were going dead. Once I was driving I noticed I had only about 10volts and it wasn't charging.
So I started to trace the problem and found that my alternator has power going in and coming out even with the ignition off. This is obviously the source of my drain but why would the alternator be getting constant voltage? what can I look at before I go out and replace the alternator?
