6.2Blazer said:My '90 with the 6.2 came from the factory with a 12SI unit. When it finally died I installed a 140 amp CS144 version on it, exact same version that is used on gas engines. The adaptor plug and the basic modifications to the brackets were the same as if you were converting a gas engine from one style of alternator to the other.
I'm not sure about the regulator or engine rpm questions. Granted, the 6.2L has a lower max. rpm rating then a gas version engine, but you are running the same rpm range during normal operation whether it's a gas engine or the 6.2L. Think about it, the 6.2 equipped trucks came with the same transmission, transfer case, and gears to a gas truck which equals same engine rpm for all speeds. Even if the gas engines can run 1,000-1,500 rpm higher for the maximum rpm, it's not like those engines see 5,000+ rpm for any length of times during normal driving.
Not quite
The diesel trucks have lower stall TC's for a reason, they run on average at lower RPM's thus the lower Stall Converters.
PLus most of the time it's the idle RPM's you need for charging and idle is lower on diesels.
