Had a drive belt misalignment issue which morphed into an attempt to clean up the 13 different ring terminals attached to the positive side of my battery terminal. In doing so, I added a junction block and fuse block, and tried to design the system like MAD electrical outlines. Everything works, but now my volt gauge is showing one of two voltages: either 14.5, or just under 12. I've got a CS144 alternator with the "s" wire hooked to the junction block. I've run pretty much everything off that junction block. I only have a 10 ga 8 ft. wire to charge the battery, and only the starter and ECM are connected directly to the batteries. (Batteries are Odyssey Extreme AGMs both about 6 mo old). I thought everything was good, but now I'm not sure. Seems this system should be running at more than 12 volts most of the time. Batteries started at 12.3v, now both are 12.1. The engine fans are really about the only large draw item I have, so I think I'm slowly running the batteries down, doesn't seem they are being charged.
Here's the issue: When I start up, the gauge will read about 14.5v, and the multimeter will show about 14.3v.After about 30 seconds, the output will drop to 12v. It will stay there, but does have random spikes into the 14.5 range, lasting a few seconds, then dropping back to 12. This is not occuring in conjunction with accessories being turned on or off. When the two 225 watt fans turn on, the voltage dips momentarily, then returns to 12 with occasional spikes up to 14-14.5v.
Here's the part I really can't figure out: So, trying to see if I mixed up something, this morning i went out and took the "S" wire off the junction block, and ran it back to the output stud, so the alt is sensing it's own output votage. Dash and multimeter now read an output of 14.3v, nice and steady, no fluctuations. Accessories on, no fluctuations.
Is this normal for this setup??? It seems the voltmeter should be reading higher than 12 v when attached to the distribution block, especially since the batteries aren't fully charged. And it seems it should definitely be running higher at the junction block where all the draw is. I'll attach a sketch of he way it's hooked up in case it would help to see what I've attempted to do.
