i have an 87 k5 with a 88 k2500 engine. That engine has a cs130 alternator. Recently my alternator hasnt been charging my battery right. If i turn on my radio, high beams, heater, 4 kc lites, and 2 bumper mounted lights, my ammeter drops down to 8 to 9 volts and thats if it doesnt shut off. Just started yesterday and i figured the alternator was going bad. So i replaced the alternator with another cs130 today. Still shutting off when i have a couple lights on and heater etc. its almost like its not charging fast enough to keep up with the load. I was looking at my wiring and into the cs130 i have one brown wire that has been spliced onto the harness from a PO and i have one wire going back to the battery on the side of the alternator. The wire going to battery is about 8 gauge with two splices in it. One splice in it is unusually warm to the touch and has made the plastic connecter on the splice soft from the head. I was going to replace this with 4 gauge wire. But after researching some, the cs130 on my truck will usually have two wires instead of just one brown like i have. Do i need to have two wires coming out of the alternator plug? Is there a wire i need to add in? Or will that one brown wire work after i replace the wire going to the battery?
