I’m using the wiring diagram below. The alternator I’m using is a stock type 105a CS130 unit for a ‘91 TBI Blazer.
1) Should the “switched ignition” wire have a fuse? If so, what size?
2) The diagram shows a fuse in the battery wire, I was going to run straight to the battery with this wire, ok? What size fuse? If it’s a large amp fuse, suggested types?
