Ok, I'm having an issue with my alternator. When the truck is running and the alternator is all connected, the positive wire from the battery to the stud on the back of the alternator gets hot and will melt the insulation off the wire. If I disconnect the positive wire it stops, but it doesn't charge, and if I disconnect the 2 wire plug on the alternator it stops, but doesn't charge.
This is on a 91. I checked the wire's at the plug and the black does not have continuity to ground and goes to the ecm (which I'm not using b/c I'm running a stand alone harness for TPI) and the pink with a black tracer runs to the fuse block, and is grounded. Is that wire supposed to be grounded? the schematic I have doesn't have a pink with black tracer wire on it, it shows a black, rust, and red...
If this is not readable or understandable it's b/c I'm sick with a fever of 103...
