Alternator
k20
3/4 ton status
Mineral Springs, NC
Ok, I think my alternator has had it. Massively pulsing lights, howling sound from the alternator, and voltmeter freakin out. So, I begin the search for a 140amp. Now, I am completely ignorant as to what style is on my truck, 10si, 12si, cs130, AHHHHHH. Ok, heres what is on the truck now, its the stock 350alternator, w/ 2 prongs, 3 wire hookup. It has the pulley(flat belt) from the alternator that was on my big block, which was a 4 prong(IIRC) 3 wire setup. What powermaster 140 do I need?
Theres this one http://store.summitracing.com/partdetail.asp?autofilter=1&part=PWM%2D47802&view=1&N=115 but it doesnt show an 87 350 truck as an application, but it does list my 88 burban 454 as an application. Which plug style do you think it would have? The 2 or 4 prong?
And then, theres this one http://store.summitracing.com/partdetail.asp?autofilter=1&part=PWM%2D47294&N=115&autoview=sku Unfortunately it has a V belt pulley, and a 1 wire hookup (dont really wanna hack the harness). Its a 10si, and the one above is a cs130.
What do I need, and if the top one has the 4 pin, instead of the 2 prong, is there an adapter for it? Someone help, I dont like strobe lights for headlights.
Thanks, Ive said it about 100 times on this board, I HATE ELECTRICAL! Chris.
Not exactly what you were asking, but alternators are extremely easy and cheap to rebuild. I'm suspecting you have another reason to go with a 140 though...
I'm in the same mode. 1985 w 10SI, I put in an Autolite w lifetime warranty, but it needs 100-140 amp. After all the surfing, it looks like at idle, 100 amp will cost $100-150, 140 amp will cost $200-to-way-to-much. Then theres on-board welding? For yours, the CS130 or CS130D looks pretty trick, you already have S-belt www.novaresource.com . Don't worry the wiring, theres plenty of adapters & info avail. But yea, definetly step-up to the CS alternators, I'm suspicious of 10SI or 12SI cranked-up to 140 amp; to get that out-put, its gotta be WFO. I spent three days at Hi and Lo 4X with CB on fulltime, alternator was keeping-up, but just. Hope there's a bunch of reply today.:D
I used the altenator from a 1996 corvette. It is 140 amp. Put it in place of 12si on a big block. Had to modify the bracket that controls the tension. Had to make the slot 1/4" wider. Been running it for four years now and it works great. Best thing is costs around $100 from auto parts. Need to put one on my 89 blazer, just have not got around to doing it yet.
If I remember right (I have CRS) it is a CS130. I put the 12si in the box and gave it to them as a core. Most counter guys have no clue what they are looking at. The only thing I had to change was the plug.
That's my kind of exchange program. Thanks.:D
Alrighty, well, after researching, Im goin w/ the cs130, and change the plug on the truck. Now I have to get some massive cable & make me new batt cables (cant have a new alt and old cables now can we ;) )
