Aluminum 2" weld in cap.
Non vented "O" ring seal. Works great for power steering resevoirs, radiator overflows or any other resevoir.
This cap can work for a non vented fuel tank cap with the application of a different type of "O" ring. We'll be adding that option soon.
For some installations a breather may be required. See our vent tube breathers for a solution to running your vent tubes up high and out of the debris.
$30.00
website link, http://diy4x.com/cart/index.php?rout...product_id=171
Here's a link for the NPT bungs,
http://diy4x.com/cart/index.php?rout...tegory&path=39
We can also assist you with the body of just about any resevoir you made need to construct. We have 4" x .125 wall aluminum tube as well as 6" on hand. Rectangular shaped resevoirs we can also do in pretty much any size.
In most cases its easier to package up a rectangular resevoir.
Bracketry and mounting solutions are just a conversation away.
$30.00
