Adventurous 4x4
I was reading the thread on the Shaffer's Off-Road built K5 and some people were questioning the solid aluminum links. I figured I would post some info on them to answer some of the questions. Will aluminum work for links, Yes as long as you use 7075. I have seen links made from 1 3/4" and 2". The Adventurous Bronco has been running 7075 2" aluminum links for over 4 years now and not one has been replaced or needs replaced and they have been abused hard. None of them are bent. The green Quad buggy runs them in 1 3/4" and the rears bent but once they bent they stayed there the rest of the season with no issues and didn't bend more. 95% of the comp rigs run aluminum links. I plan to run them on mine. I am going to run 2" lowers.
This rig weighs about 5000 pounds and probably sees more abuse then a normal wheeler does.
) The idea from what I'd heard is that it's more "springy" than steel and will return to it's original shape, where a steel link can only bend or kink. I don't think it's as much a weight savings thing as it is the behavior of the material under bending loads.
