Aluminum PTO covers
cybrfire
1 ton status
Iowa
Just up on the website,
http://diy4x.com/cart/index.php?route=product/product&path=18&product_id=199
Billet Aluminum PTO cover.
A little bit of functional flash for your undercarriage. Fully machined in house from 6061-T6 aluminum. Proudly engraved right on the face, "MADE IN THE U.S.A."
3/8" NPT port for filling or draining depending on how you have your transfer case clocked.
Aluminum fins aid in keeping things cool.
Kit includes the cover, Fel pro gasket, 6 - 3/8" socket head cap screws and 6 through hard washers.
So is there a differance in between the stock cover and the billet in regards to tempatures during use?
Yes.
Thanks for the compliments guys!
BTW, I wasn't eating cookies when I took the pictures. I swear it.
It doesn't specify, but these are for the 205 pto port right? Might want to add that to your listing, you'll likely get more hits on it from searches.
Yep, 205,203, sm465, nv4500 etc.
As far as pto ports go, if it has the 6 bolt pattern, this should work for you.
You know you want 1 or 2.... Maybe 3.
