I was driving my blazer to school yesterday, I got about half way there and it felt like I lost all power. From a dead stop or from cruising (speed limits 35, I was doing about 45) I would go to WOT and it would act like a turd. Wouldn't down shift and would barely accelerate. From a stop it would still be a turd and not accelerate and would take too long to shift into second. On my way home from school it did the same thing. The first half of my trip it worked like normal, would pull hard from a stop and would downshift under heavy acceleration. Then I got it up to about 50 mph and all of a sudden I got a bad vibration and it started acting sluggish again.
I'm thinking MAYBE a bad torque converter, or it doesn't unlock after locking up, causing the turd like symptoms? I don't know anything about how Torque converters lock up, so this is just a guess.
Specs are in my signature, 350 with TPI and a TCI (forget which model) 700r4. When I installed the engine/trans combo I setup up the kick down cable (I'm pretty sure that's not what it's called on a 700r4, but can't think of the correct name), but it could be out of adjustment now I guess. The ECM I'm using for the TPI is the 1227727 with a custom prom.
