Am I missing a crossmember?
dr1553
Lake Jackson, Texas
Everyone,
I have just one crossmember that my transfer case sits on. I have seen in pics on here that people have two. The one that I have and then one further back connected to the first one with a plate.
Am I missing a crossmember? It's a '72 K5 with 350/TH350/NP205.
Thanks,
David
I have one crossmember under the adapter and the side mount on the 205. I think the 2nd crossmember is for the skidplate.
I have the double one.
I use it alot too /forums/images/icons/grin.gif
both cross members are identical and the skid plate bolts to both. So it makes real good scrapes on thoes pesky bolders /forums/images/icons/grin.gif
Some havum some don't, duno what is the deciding factor for GM to put the double verses the single?
Mine came with a 4spd, maby that is why?????
Burt I think it was a factory option on our trucks. I need to get a 2nd crossmember and make a skid plate for mine.
Burt,
I think it does seem like the gear grinders have two and those with slush boxes have just one. Maby thats it.
Later,
David
I second that opinion. I have the 4-speed sm465 and it looks like a stock second cross-member and skid plate. Just one more thing to unbolt when I took it out last week.
Matt,
Man...I need to give you a call! Sorry....I've been really busy lately. Trying to get my blazer on the road, trying to study for my written, working 8 a day and I gotta eat and sleep sometime in between!
I would like to take a look at your blazer also. Looks like you have alot of work in it!
Later,
David
Neither of mine have the 2nd crossmember. I found that a later model TC skid plate, bolted only to the single crossmember with 2 bolts, will fit without modifications. Much easier than installing a second x-member, but surely not as beefy....
