First, a little background. I have a '69 Impala four door hardtop that was my first car. I drove the wheels off the thing the first few years I had it, then I started acquiring more cars and it got driven less and less. Now it's to the point where it only gets driven a couple times a year because there's usually something wrong with it from too much sitting. Last year a rear brake line blew and I've never even had the rear drums off yet, so the shoes are likely well worn out. The fronts are also drums and are non-power.
Now here's where it gets a little interesting. I just picked up a rear disc setup for free from '00-ish 4x4 s10 blazer that should bolt up to the rear flanges of the '69 10bolt housing. Yes, that's right, I would like to add rear disc brakes to a car with front drums
I know it sounds silly, but is this a bad idea? My way of thinking is that doing ANYTHING to this car is better than nothing... and it would be free! Maybe if I get working on the car again, it will get the ball rolling on fixing up the rest of the car.
Thoughts?
Thoughts?
I found this out after beating the drums off the rear and pulling one axle. Apparently the backing plate flange on a 8.2 10bolt is larger than the flange on the later 8.5 10bolt used in the f-body (that this swap has been done on). I always thought they were the same
