Everyone here knows I like straight sixes...I'll be following this thread..
Over the years I've had a few 250 GM straight sixes,a 235 in a '56 Chevy pickup,and I liked them all..one truck I had,a '79 C-10 Bonanza with a 250 (integral head design,not GM's best effort) had a 2 bbl Rochester E2SE carb that sucked,I adapted a Edelborock 600 CFM carb to its original intake ,but had to disable the secondaries ,it didn't like that much air & fuel being dumped in..it ran very well on the primaries though..
That engine lost the #6 piston at 117,000 miles,the fact those "camel humper" integral head engines always spark knocked probably is what ate the top ring land--the cylinder got scored bad,and I drove it 20 miles home rapping--I hated to swap a V8 into the truck,but I did ,I had a 305 from a van I put in it...I felt it went better with the 250 six in it..
One thing that affects the inline engines is the fuel distribution ,the end cylinders tend to be lean while the center ones run richer...the "heat riser" is needed to heat up the underside of the intake to help promote better fuel atomization,some aftermarket intakes lack any heat source,others have coolant pasages cast into them to pre-heat the air fuel mixture..this improves cold driveability and wards off carb icing..
I rode in a Ford Econoline van a friend had ,with a 300 straight six and a C-6 transmission--he put the Clifford intake on it,a exhaust header,and found an aftermarket camshaft that was ground for more low end power...he used a Holley 4 bbl 390 CFM carb on it..
The thing was a torque monster..taking off from a dead stop required a very light foot on the throttle,or you'd squeal the tires just past idle..it accelerated much better than stock,and he even claimed it got slightly better gas mileage...
The Holley proved to be a pain though,he had multiple issues with it flooding,and popping power valves,the engine tended to spit back thru the carb when cold--he tried a Q-jet carb on it,which required some adapting,but in the end it ran even better with the Q-jet..when you floored it,the secondaries only opened up as far as they needed too,while the Holley just opened them up too much too soon and would result in a bog ,then it would take off..
It will be interesting to see how this build pans out..
