I've used Russell, Earl and Summit. In my opinioin the Summit ones are not worth it. I ordered over $300.00 worth of summit -6AN fittings for work a year ago and most of them leaked (gasoline, 60psi). I called Summit and they wouldn't do anything about it. I replaced the fittlings with Earl's, and no problems. I might have got a bad lot of them, who knows, but upon close inpection of the fittings the seating surfaces of the summit ones appeared to have tool marks from whatever tool they use to form the sealing surface. Bad quality control, which is the reason they are cheap I guess. I was able to use some of the summit ones by inserting those little thin aluminum flare gaskets.
