AN line mounting on frame and fuel tank vent location.
Cucv_M1008
Cthulhu Forever
Pendleton, Oregon
what are ways people are mounting AN fuel lines to the frame, I have the loop kind that just screws into the metal, but im looking for something a little cleaner since I have feed and return lines on the frame.
I was going to use the DIY4x kit but i did not get a chance to order it from diy4x before he closed. what are people doing for stock location fuel tank venting. Any Suggestions would help.
Are you trying to replace all of the metal pipe or just the ends?
There are 3/8 pipe to -6 AN compression adapter fittings available to let you plumb directly to the tank pick up. You have to cut the flare off, but that is it. I am pretty sure there is enough length to the stop sender pipe. Do the same with the return side. You might have to get a 1/4” to -6 AN compression fitting for it though.
Do a search for AN hose clamps and all kinds of options show up.
I would also suggest PTFE core hose. PTFE is basically Teflon. It won’t degrade like the hose core stuff does.
Lines are allready run I just don't like the loops they are mounted to.
Are you looking for single or dual line clamps?
I love Google images for stuff like this. For this I’d search for something like “hose mounting clamps” and just scroll through the endless product images. I’ve done this many times for obscure or cleaner hardware / brackets / etc.
I’ve bought stuff before from a company that I thought was named “Taylor Made” but I can’t find them now.
I've used a variety of clamps and separators and I drill & tap the frame to secure them.
