A few weeks ago I started hearing a slight knock in my engine. It ONLY does it when the engine is at operating temperature, not cold and it's not a bearing noise. It only does it between 2000 and 3000 rpm and it goes away when #1 plug is disconnected. This noise has the same sound as detonation, but it's rhytmatic with engine speed. I was thinking piston skirt, but someone mentioned a bad lobe/lifter. Any ideas or opinions? This engine has 221k on it and still runs very well and has a constant 30psi of oil pressure @ idle.
