Stomis
Professional Amateur
Im considering running aluminum hard lines for my feed and return on my diesel swap in the trooper. It will save me from having to have a flare to AN adapter if I use steel lines. However Im concerned with aluminum in an offroad situation. Do I need to worry about it catching dings easily? Obviously if something is going to crush a line its going to crush a line. Im more concerned with say a branch hitting a line and aluminum tearing really easy compared to steel that might have more strength.
Also are there any line options for power steering other than braided stainless? I know that power steering is in the range of 750psi and stainless seems to be the only thing I could find which is rated up to 1000psi.
