Okay, probably pretty worthless tech but I found it halfway interesting to see the internal structure of a topper. It weighs right around 200 lbs. (I've weighed the Blazer with and without the topper) and wasn't nearly as easy to hack up as I expected.
This is off a '90, so basically the last generation topper and contained the upper mounts to the 3 point rear seat belts so not sure if it had more reinforcement than earlier versions or not???
This is the B-pillar of the top. Right side is the seal that goes against the cab, bottom sits on the rail, left side is part of the window channel.
The portion that sits up against the cab has a steel channel (exposed on the outside)...this is the side facing out with the bolt hole in it.
This is the back section, like you standing on the side of the truck with the front towards the left...bottom sits on the rail, right side is the upright very back of the top, left side is the window channel.
This the above piece if you were standing towards the front of the vehicle looking back. The bottom is the part that sits on the bedrail. Just single layer fiberglass.
Same piece, but if you were standing on top of the vehicle looking down the back corner. There is fairly substantial formed metal piece (kinda' "S" shape) between the layers of fiberglass.
This piece is if you were standing at the back of the K5 looking forward, this is the upper roof like (top of picture is the roof, bottom is the rear window channel) as it is cut at the middle of the top going forward.
This is looking in from the right side of the above piece, you can see the large "S" shaped metal shown in above that goes up the C-pillar (very back upright) and continues to wrap around over the rear top.
Same piece as above, but looking through the middle towards the outside. The metal is actually double-layered over the rear window.
Here is the interior piece where the upper rear seatbelt bolts to (if you were sitting in the back seat and looked up at the part running from front to back). The inner fiberglass part you see on the interior is facing up, and the metal brace that runs from the B to C pillar is the bottom. The outer fiberglass layer is not present.
Here is where the upper rear seatbelts mount.
With you being in Ohio I could of bought it off you and had you cut it for my topper thought.
