jonathon
At least in terms of work on my Blazer to get it mall capable
I've got a Q-jet inbound from I-5 Automotive
That'll make a world a difference replacing the Edelbrock 1407 that's on there..
Stuff left to do that'll hopefully be done in '08:
For me half the battle will be saving the money up to do all this on a college budget, but in the end it'll be worth it! More Ramen and .22....
That'll make a world a difference replacing the Edelbrock 1407 that's on there..Stuff left to do that'll hopefully be done in '08:
- Finish rebuilding tailgate, got my GM inner and outer seals!
- Fix the oil leak(doing that next monday) DONE Slight drip from the intake, but not enough to make it worth changing the gasket.. rear main, oil pan, and valve cover gaskets replaced.
- Exhaust - decided to put manifolds on and go from there.. engine is stock and will stay that way
- Reroute the breather tubes on the diffs, trany, and t-case into the engine compartment
- Flush the brake lines and do the rear brakes(they are okay, but one of the drums is fubar'd).
- 5 Tires and wheels, hopefully I can find something decent locally
- Floor pans need some patching, nothing major. For now they'll probably be rattle canned till I get the materials for POR and Herc together
- Door and door window seals and the like.. need to get the part numbers and will order from GM Parts Direct.. quite a price difference than the dealer(Found this out AFTER buying the tailgate seals).
- ORD steering box brace
- Hand throttle
- Electrical work.. would like to have my washer pump working among other things.
- Speedometer - cable is good, speedo is good, but the cable doesn't turn going down the road and in the t-case it doesn't feel like it's engaging anything. Need a gear??
Learning is half the fun, though sometimes it is frustrating without good guidance on the spot.
I thought about trimming it and then after filling it up with oil checking it and then remarking the dipstick...
From my reading and searching I think the possibilities are the air horn is warped, float level needs adjusting, or the screws going into the air horn were tightened too much. Another possibility(again from my reading, I don't know if this could be the case) is that the front mounting bolts could've been tightened to much.. but I did put them the way my book said.
