angled shims
npayton
santa cruz
i only have half of one stil hangin on .. i cant tell if its like a 6 or 8 or?...well what degree to make the new ones and should i mill allumium or steel? weld back on or just rely on the bolt through middle? THANKS!!
If you have a cv shaft 2* shouldn't hurt. I would just use the center bolt, but I suppose it depends on what you plan to do with the truck. If you have half you should be able to figure based on the upper (or lower) portion you have left if you have a protractor and a straight edge though.
You could always measure the other side too, seeing as you may as well make two considering one broke in half:whistle:
Aluminum should hold up, but again that depends on what you want to do. Steel is cheap and easy to come by.
Let us know what you come up with.
all i have is 1/2 of the one :( protractor didnt think of that..THANKS as for what i plan to be doing that depends on if my truck holdsup its a tank for sure.
used a 5 degree steel welded itso theres no comin back off thanks for your help :D
stuck in the mud pit <embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid23.photobucket.com%2Falbums%2Fb354%2Fnataliepayton%2FDSCF4126.mp4">
just finished building first action i got towin jeeps from the minute i got out to the hills
hey thanks got it from walmart its Krylon italian olive like $2.97 a can the top is krylon camoflauge green:) includin primer and paper i spent $176..i donno about more of me..theres a reason my parents stopped after me! if your ever round central cali (HOLLISTER HILLS srva) im always there come an love new buddies to wheel with! just putta detroin in the other day pretty happy with it :)
