Got Smoke?
Ok I pulled my transmission & transfer case out a couple of months ago to install a new clutch. I had my flywheel resurfaced and ordered a new clutch kit from South Bend Clutch with a diaphram(sp?) pressure plate. I installed a new clutch fork and put new bushings in the Z bar linkage, added the LONG clutch fork return spring (ordered both but couldn't make the little one work?), and also swapped out the large garage door style OEM spring for the new style pedal return spring.
Now I have a EXTREMELY annoying POP at the top of my clutch pedal travel. Clutch engages and disengages fine...and sometime the pop will go away for a few shifts...but usually comes back. Any idea what's causing this and how I cure it?
He's usually right on the money on his stuff, but I've never heard this before? Anybody have any insight?
