LQ4-K5
Registered Member
Is there anybody out there making a 52" rear leaf spring, in the 6" - 8" lift range, that has the capacity of a 3/4 ton truck spring? All of the aftermarket lift kits I have found that advertise a "K20 lift kit with 52" springs" is simply selling a 1/2 ton capacity kit. I have a 78 3/4 ton single cab and I don't like the idea of lifting it with 1/2 ton capacity rear leaf springs. I have two other backup plans, have alcan make me some 52" lift springs to my specifications, OR maybe a shackleflip with a 2" or 4" lift 56" spring. Any thoughts???
My truck has the 2200 lbs 6 leaf packs from this chart.
http://www.generalspringkc.com/index.php?p=catalog&parent=47&pg=1
you wont be disappointed
but they wont be able to compare in ride
