mocrawler
I have an 89 1/2 ton suburban.The brakes have all but quit working so I removed the wheels and checked the pads . They are all fine. I then tried to bleed the lines thinking maybe they had air in them. Even when I pump on the pedal no fluid comes out of the lines. And yes the master cylinder is full of fluid. I am going to replace the master cylinder tomorrow. Do you think i'm on the right track?
I loosened the lines at the brakes and it flows fine. I think all of the calipers are plugged. I know they've never been changed. I guess its about time.
