...so that had to be ground out heated and pounded back into its proper position, thank you previous owner!good start, is that some kind of rubber molding on the bottom?
holy huge stinger batman!![]()
After yanking off the front bumper I opened up a can of worms.
You folks here obviously have far more experience in this area than anyone I can think of, so input would greatly be appreciated
Looks really good, maybe on the heavy side. How much does it weigh?
well I do agree with the stinger amplifying the visual movement, it jiggles side to side and is rock solid as far as front to back, its especially visible in the corners that stick up at the edges of the hood. The bumper is held on by eight 1/2" grade 8 bolts on 1/4" plate beveled and welded to a 1/2" plate of steel! what gives? The front body mounts are pretty dang soft, like 'squishy by poking it with your finger' soft...
