Another carb question.
stump_puller
Frankfort, Ky.
/forums/images/graemlins/1zhelp.gifI done a search and good some good directions to go. But here is my problem. I just got the 350 going I'm having problems dialing in the carb. It is a elebrock 1406(electric choke 600cfm). I put on aelectric choke conversion kit and I also put in the offroad needles. Now it idles alright but when I put it in gear it bogs down then dies. I adjusted the mixture screws to achieve the maximum rpm and the maximum vacume. But that still doesn't seem to help /forums/images/graemlins/dunno.gif.
You carb guys got any ideas? I would to get this thing up and running thats all I lack to get her on the road.
I hooked the vacume gauge on the drivers side port that was capped off. If this is correct do I need to block off the distrubtor advance hose(like checking the timming).
Thanks in advance,
Don
/forums/images/graemlins/waytogo.gif
You should hook up the guage to a manifold vacume port. Some of the ports on a carb dont give a true vacume reading.
All other vacume lines should be either hooked up or plugged
