Ok, finally have a few moments to work on the truck again. Trying to finish up the hydro install. I rigged up a sweet bench bleed system that holds the slave cylinder in 3/4 of the way as per recommendations on here.
Should I have a perfectly firm master cylinder rod, meaning no movement whatsoever, or will there always be a little bit of play there? I've got it very firm with about 1/8" rod travel before it gets too firm to move at all. More bleeding, or...?
