My buddy has a 1985 K30 Dually plow truck with dump body. This past year he developed pulsing while braking and death wobble. About 8 months ago he put on new Calipers, Rotors, and pads which cured the brake pulsing but when he put on the 9.5' plow, anything over 30 mph and a bump equalled no control over the truck (death wobble). He installed new sway bar bushings as those were shot, and he put on brand new leaf springs and new hardware. I had him install a new drag link and adjuster, new tie rod ends and adjuster, and new steering stabilizer (little/no effect). I then ordered him for Christmas a complete front end rebuild kit (new upper/lower kinpins and associated hardware), new axle unjoints, new spindle bearings and seals, new inner/outter bearings and races on the hub, and all associated seals. We put those in a few weeks ago and everything seemed fine. He called me to tell me today that it came back after hitting a bump with the plow on. He said it was just as violent, but not as easy to bring about or as often.
I have a rebuilt steering box from Matt at West Texas that I'm going to put on, but I don't know if that will help (although it can't hurt). This truck is STOCK as stock can get. No offroading, factory wheels, tires, gears, motor, tranny, etc. and Everything from leaf springs to seals are all new in the front end.
Just to be safe, I am going to recheck all fasteners, install the rebuilt steering box, and have him get it aligned and tires balanced, but does anyone have any ideas if that does not work??
I don't like the thought of using washers on the kingpins especially on a STOCK truck that was COMPLETELY rebuilt, but if I have to I will (as death wobble is not acceptable). I did several searches and weeding through the posts I see that fender washers are what most use, but could not get a consensus on thickness or diameter. I saw one person post about a washer that was 2" OD, is that the ideal size?
Thanks in advance.
Thanks in advance.
