I just finished swapping in a Dana 60, 52's in the front, and crossover, I took the jimmy for a drive, only about a mile from the house, on the way home I hit a dip in the road at about 35-40 mph and that's when I got my death wobble. When it did that the battery shifted forward in the mount and the positive terminal hit the radiator support and blew some fuse. I pushed the truck off the road and took some wire and ran it straight from the battery to the junction block on the firewall and it cranked up and I got it home.
Anyway, everything up front is new except for the kingpins themselves and everything is torqued to spec. I've read about the washer trick, but I have everything for hydro assist, just wanted to work out the bugs before adding it just to eliminate that if anything was wrong. Should I just put the hydro assist on and forget about it? To get this thing aligned at a shop do I just need to explain to them what all I did so they don't look under there and not know what's going on? I'll figure out the short, but are there replacement inline fusable links or should I just cut out the bad one and splice in a new fuse?
