So I'm looking for an SRW Dana 60 right now. As I'm considering different potential axles, do I need to be cautious of the gearing that's in the axle? I am going to have 5.13s installed, and would rather not have to install a new carrier in addition to gears. Is the carrier from a Dodge 60 the same as the carrier from a Chevy 60? Seems they would be, Dana is dana is dana... maybe? Obviously all 60s aren't the same between manufacturers.
Also, I have a 14BFF w/ 4.10 gears and a Detroit. I'd like to have it regeared for 5.13s and I'm curious to know more about the thick vs. thin gears. WIll I need a new carrier in that axle?
The only difference (IIRC) in carrier "size" is where the ring gear mounts. The smaller carriers are a little thinner and set the ring gear closer to the center. A thick cut gear is needed when going to 4.56 and up, so the gear is pushed back towards the pinion gear. The pinion gear is also a different size I believe. The larger carriers are already thick where the ring gear sits.
hmm
in the meantime it'll just be a bit snottier off the line...
