Another doubler Question
You can use that 203, you will need the 32 spline input (we carry them, no problems there) and you'll need to re-drill the front face of the 203 gearbox to match up to the round bolt pattern on the 4500 adapter housing. You may need to do some clearance work on the bearing retainer and/or the adapter housing but it's all pretty simple.
Thanks for the info. I saw the 32 spline input kits for the 205 on your website, but not for the 203. What would the price be for the 203 32 spline input adapter kit? If its over $200 I might as well just buy one of your rebuilt 203's with the 32 spline gear already in it. Thanks again, Rich.
The 400/203 input drops right into the original bearing so all you would need is the input gear and they run $150.00. 203's are pretty easy to work with compared to the 205.
Unfortunately we have to do that sometimes but it's typically worth it. It sure would be fun to do this for free though, imagine that!
