morcav
Registered Member
I'm really in a herd spot right now. I'm set to get out of the army in a month and I'm getting really bad vibes from the rear now. I have angled 4" blocks out back and they were pointing my pinion to far up so I flipped them around to point it down and it made it to where the driveshaft was at such an angle that it was hitting the u-joint bolts, so I flipped it back around and now my vibes are worse. I think if I shim it my driveshaft will be at to much of an angle and get to close to those u-joint bolts again. I really didn't think I was going to run in to this many problems with only a 4" lift and I have to drive this thing with the family 2600 miles 30 days from now. I've done searches and every one seems to be recommending shackle flip and a cv Drive shaft, is this the only way I will get rid of this and if I do it how hard will it be with basic tools and will it fix the problem?
