another hi steer question
twoslo4five0
3/4 ton status
Living in a dump, VA
so im looking at my hi steer today...ive been told that the stock tie rod is to long for hi steer...one tre is like 4 inches long the other is short...i was told that you can run a dodge tre on the side thats long and fixes the problem...anyone got the part number and if i didnt go this route would it be accetable to cut and sleve my current tie rod
ES2233L : GM pass TRE (long threaded with stabilizer hole).
ES2010L : Dodge pass side TRE (short threaded rod)
ES2234R : driver side TRE
ES2027L : high misalignment drag link end
ES2026R : high misalignment drag link end
:bow:
what are theese part number for (brand) also if anyone know if this will make my tie rod fit then that will be help full as well
