Thought I would protect the lower kingpin zerks a little. It is only 1/8" wall, but I had it handy (I cut it off the end of my cheater bar
). The tube is short (1/2" long and 1 1/4" OD) so hopefully it will hold up for a while - if not I'll grind it off and find some 3/16" wall.
This is my first welding in ~10 years. Before that I used a MIG welder less than half a dozen times and gas and stick just 2-3 times each so I don't really know what I'll doing. It was a [EDIT] Millermatic 130 [/EDIT] MIG welder at work. The bottle was almost empty and I'm not sure I had the regulator set right, but I did hear gas come out when I pulled the trigger. This is with the voltage maxed and the wire feed almost all the way down. I didn't get as much penetration as I wanted, but it'll work. I prolly should have put a chamfer on the end of the tube before welding, but I figured 1/8" wall shouldn't be a problem.
This is a warm up for welding on my steering box brace and "customizing" my stupid duty towers, so let me know what you think.
