Another Mig post. Hobart welders
Yes, Hobart is made my Miller. Bascially what you're getting is a Miller with a few cheaper parts inside. Little things like I believe the spool drum is plastic where the Miller is metal....
:thumb:
From what I've heard, you'll probably be happy with it!
i have that same unit. it has 35 wire now and i can weld the hell out of any thing on my truck. and if smaller wire i can do body work. i like it. the price for the bottel is that rent or own the bottel?
Hobart is pretty good stuff. When I was at 4x4 Iron's shop in Colorado a few years back before the move Tim used a Hobart 175 I believe it was. I use a Miller 135 quite a bit and I really like it. Best 110V welder I have seen and used. Hobart is one step down from the True Blue Miller.
Harley
a 135 is a 135
lincoln, hobart, miller pretty much the same capacity and all very similar units.
i understand you are looking at the 140 wich is a good welder i almost got one but i found a deal on a 135. as it is now my lincoln 135 can handle pretty much anything on my blazer, so a 140 should work out great.
I havent gotten the gas yet im only like on my 3rd or 4th roll of self shileding wire.
Get a auto darking helmet. Your welds will come out so much better and even in dim areas you can see whatever you are welding. 49 bux on harborfreight. Cant beat it
PEace
I've got the Hobart 135 which is essentially the same unit. Bought it used for $229 and it's been GREAT.
Oh yea tim, that one you ripped off of me. Good welder i hear
Thats *really* good to hear cause that is the one that I'm looking to get this spring. I want to build some bumpers and maybe a roll bar/cage and also some bodywork. Good to hear that is is capable of that.
I bought a Handler 180 about 8 months ago. I love it. Had the gas flow meter go out and took it back to where I bought it. They warranteed it no questions asked and everything works fine. I've heard one of the differences between Hobart and Miller is the drive roller assembly. The only thing I'd like to see on the Hobart welders is a infinately variable voltage selecter instead of the 1, 2, 3, or 4 detents, but that wouldn't stop me from buying another Hobart Welder.
I'm sure the shop where your buying it knows what they are doing, but I'd just inquire about the shielding gas. You mentioned Argon, but for mild steel you should have a 75% Argon, 25% CO2 mix. Straight Argon is for either Aluminum or Stainless Steel (I'm not sure which), and you can kill your regulator if you run different gasses through it.
Scott
I have a hobart 110v and love it my sales rep at praxair talked me out of the miller version that was over $100 more when he showed me the increased range the hobart had
I have a Miller 135 that I use here and there for some time now. It's a good little machine. I think it does 1/4" ok but not much more than that. It's about to get sold off. (already spoken for) I replaced it with a much larger machine. Since I have the tig in the shop I don't really need the 110 anymore. The hobart should do well for you for small projects.
I had a handler 135, good welder but a little small for some of the stuff I wanted to do. I bought a new handler 180 on sale last summer for about the same price as what you quoted, my point is if you can use 220, then only buy it once.....
Just looking through the new Northern Tool catalog and they have the Handler 125 for $345 and the 140 for $480.. And Free shipping....
I picked up my Hobart 140 at Tractor Supply a few months back for $440 I think. They were running a winter special. Check em out. If you have a store locally, you wont pay for shipping. Tax might suck though.
I saw the welder at tractor supply, but I'm saving some money on the tank and the extra spool of wire if I buy it all at the same time. "package deal" savings. It would cost more if I bought the welder at tractor supply, then the tank and wire at the welding supply house!
